Parker SGP 401W Water-Cooled Push Pull Gun
PARKER
SKU# EV-SGP401W
The Parker Technology SGP 401W is a water cooled Push-Pull gun designed to feed aluminum wire and serve as a "pull" motor gun which assists in feeding large diameter spools of Aluminum Wire. The gun features an ergonomic pistol-grip style which is easy to hold and reduces fatigue. This means longer, uninterrupted welds without having to "regrip" or reposition the gun. The 8m (25ft.) cable length gives you plenty of room to move about and get to where you need it. This gun is designed to fit all Everlast models with remote speed control capability (see below) to fit the Power i-MIG 353DPi. Also it can be used with other Push-Pull Capable Everlast MIG welders that are equipped with a power outlet in the rear and used in conjuntion with a water cooler (optional). It works especially well for Pulse MIG work that require long welds and continuous, non stop welding. The 3000-hour motor life expectancy of the unit means this push-pull gun is designed for long term commercial/industrial fabrication. When equipped with optional drive rolls, this unit will feed aluminum wire from .035" to .063" (0.8mm - 1.6mm) wire, perfect for pulsed-MIG operation (standard equipped drive roll = .045"/1.2mm). The gun is rugged with a 100% duty cycle at 400A output. Water-Cooled Push Pull Gun for Aluminum operation Up to 400A capacity @ 100% Duty Cycle Optional drive roll sizes and types available Ergonomic Pistol Grip Style 25 ft. cable (8m) Drive Roll U Groove .045" (1.2mm) included Binzel Type 401 for easy sourcing and interchange For Power i-MIG 353DPi
