$0.00
Go to Checkout
SKU# EV-DSP360A-24-P10-80ER
Parker DSP 360 Spool Gun
Spool Guns
$599.00
Spool Guns
The new Parker DSP 360 Spool Gun is capable of 300 amps of welding power.  This unit is heavy duty and designed to go the distance.  The 36 series consumables will interchange with Everlast units that are equipped with 36 series MIG guns.  (Note units that are not equipped with the 36 series MIG gun as the standard main gun, can also be upgraded with 36 series main gun as an option if matching consumables are desired).  This gun is a pistol grip style with Euro-style connector and amp controlled from the handle. Not for use with PowerMTS 400 or not listed MIG models. Comes with .040" U-Groove Drive Roll. Recommended for current models: Power i-MIG 230i Power i-MIG 253DPi (adapter required) Cyclone 262 Cyclone 312 Power i-MIG 353DPi (adapter required) Power i-MIG 275S Power i-MIG 275P PowerMTS 221STi Lightning MTS 225 PowerMTS 251Si PowerMTS 252STi Lightning MTS 275 Specify replacement contact tip size when ordering consumables. Note: Spool Gun is equipped with M8 contact tip holder.  To use M6 contact tips please order new M6 Contact Tip Holder
1 year
