If you want a sturdy, high weight capacity table that stores away neatly and carries conviently, the Nova Welding and Tool Table is the answer. This table can hold up to 1000 lbs of evenly distributed weight. The legs are adjustable for setting the height you need. The table can be adjusted from just a few inches above the ground up to 39" high. This allows plenty of room for matching the table height to the requirement of the job. The max height of 39" also is a convenient height for welding while seated or standing for people over 6 feet tall. The table has a sturdy top made out of 14 gauge punch plate metal with 3/4" (19mm) diameter holes for tool fixture mounting with the optional tool kit. This versatile table can also be used to mount metal chop and cut-off saws, along with other jobsite tools such as planers and tile saws.
