$0.00
Go to Checkout
SKU# NOVA-LCN-3690-1-KIT
NOVA TIG Conversion for Lincoln® PowerMIG 210MP
Nova TIG Torch and Pedal Kits
$289.00
This kit is designed for use with Lincoln Electric's PowerMIG 210MP. This quality NOVA TIG foot pedal and torch kit is designed and engineered to be used in place of the Lincoln K3690-1 Kit. The kit includes everything you'd expect to get with the K3690-1 Kit to get started TIG welding with your Lincoln PowerMIG 210MP (K3693-1).  You'll need to use your existing regulator with this kit. The kit includes: NOVA 17V (gas valve) 150A rated torch with the 15 ft Ultraflex lines with DINSE connector. Gas line to regulator. NOVA Foot Pedal with cable and amphenol connector. 6 pin Amphenol Connector Kit with quick plug connectors for internal connection. TIG consumable Kit with 3 cups, 3 Collets, Collet Body and Backcap to fit 17 torch. (Tungsten not included) All you'll need to do is install it exactly where the Lincoln K3690-1 Kit is located. Guaranteed to be compatible. NOTICE: This torch and pedal kit is not made by or in conjunction with Lincoln Electric or its subsidiaries. This kit is made by NOVA Welding Industries.  However, this TIG kit is intended to be an interchangeable replacement for the K3690-1 Lincoln TIG Kit. It is not an exact identical kit.  Some small differences in appearance will be evident that do not affect fit, interchangeability, or function.  These kits have been tested for function and accuracy in conjunction with the K3693-1 welder.
1 year
