$0.00
Go to Checkout
SKU# NVA-26R-125-35QD
NOVA 26 Rigid-Neck TIG torch 12.5 ft 35 Dinse
Air-Cooled TIG Torches
$149.00
This unit is the standard type 26 series TIG torch with rigid head and good choice for OEM replacement for Everlast Units.  This size torch is the largest standard  air-cooled torch size commonly available. Torch includes 2T/4T switch. Keep in mind that this torch is rated for 60% duty cycle at 200A DC and 175A AC output.  Welders capable of welding at higher amperages are listed below. This does not mean that the torch can be used at any amperage with that welder. Select an appropriate torch for the amperage range at which you anticipate welding.  It is advisable to have a range of torches to fit different applications. Air-cooled 200 Amps @ 60% Duty Cycle DC 175 Amps @ 60% Duty Cycle AC 12.5 ft of Flex Cables NOVA quality Straight Head (Rigid) DINSE 35 Type with 1/2" connector and gas quick connect Measure or Confirm size/type before order on older models Fits All current and past PowerTIG models, except early 185. Fits All current PowerPro models Fits All current PowerMTS/Lightning models Fits PowerARC 200STL, 280STH Does Not Fit Power i-TIG, SuperUltra, PowerUltra, UltraArc models 200 amps and under due to connector size Does not Fit PowerArc models except ones listed above
1 year
