MASTER Gas Lens TIG Kit 2.0
PREMIUM 9/20 TIG Consumables
SKU# EV-MTR-GL-V2
This MASTER Gas lLens TIG Kit is designed to fit all 17, 18 and 26 series TIG torches as well as 9 and 20 TIG torches, and is designed to compliment the PowerTIG 210EXT, 255EXT, 400EXT and Typhoon 230, 330, and 500. It includes common sizes of gas lenses for the torch kits included on these units. The ceramic gas lens are designed for for day-in and day-out use for welding draft sensitive metals.The design improves laminar gas flow and helps to reduce gas waste while improving weld quality. It includes a variety of cups and parts to get you started with gas lenses. Includes the following: (1) Foam Lined Protective Box (1) 1/16" GL116NQ Gas Lens (1) 3/32" 4GL332NQ Gas Lens (1) 1/16" 45V43NQ Gas Lens (1) 3/32" 45V44NQ Gas Lens (1) 1/8" 45V44NQ Gas Lens (1) R type white Ceramic Champagne Nozzle with screen for 3/32" (1) Short Gas lens 4GL332 (1) 1/16" Wedge Collet 4C116GS (1) 3/32" Wedge Collet 4C332GS (1) 1/16" Wedge Collet 2C116GS (1) 2/32" Wedge Collet 2C332GS (1) 1/16" 17CB20 Collet Body (1) 3/32" 17CB20 Collet Body (1) #4 Alumina Cup 13N08 (1) #5 Alumina Cup 13N09 (1) #5 Alumina Cup 52N59 (1) #6 Alumina Cup 52N59 (1) 32.5 MM Clear Cup 2P7GS-L (1) #12 Alumina Champagne Cup 53NACN12 (1) #14 Alumina Champagne Cup 53NACN14 (1) #16 Alumina ChampagneCup 53NACN2316 (1) # 53 Alumina Champagne Cup 53NACN2324 (1) Champagne Clear Cup with Screen Pack (1) Clear Nozzle 28 53NQCN (1) 3/32" Screen pack for nozzle 53NQSP (1) #14 Champagne Clear Cup with adapter and screen (no guard) 54NQCN-14 (1) #16 Champagne Clear Cup with adapter and screen (no guard) 54NQCN-16 (1) #24 Champagne Clear Cup with adapter and screen (no guard) 54NQCN-24 (2) 14.8x9.5x 2.65 Sealing Ring (2) 12x7.2x2.4 Sealing Ring (2) 3/32" 2% Blue Lanthanated Tungsten (2) 1/16" 2% Blue Lanthanated Tungsten
