$0.00
Go to Checkout
SKU# EV-HRCN-220
Multi-Process: MIG/TIG/Stick/Plasma
$2,250.00
$1,501.00
Save - $749.00
SKU# EV-HRCN-220
  • Unit Weight: 95 lb
The Hurricane 220 MTS-C is a true Multi-Process welder. In fact it is one of the first of its kind on the market with the ability to both weld  and cut in the same compact unit. The unit actually offers you the abilility to MIG weld, AC/DC TIG weld, DC Stick Weld or Plasma Cut with a simple torch change and button press. The unit has the perfect size to be a serious contender for use in portable repair and general light fabrication operations. Because of the Plasma capability, the unit can be taken anywhere and you'll always have what you need.  You'll never need to load extra machines, or go off wishing you had brought something else to the jobsite. The right tool for the job is always at hand. With up to 225A of MIG and TIG welding power, you'll be able to weld most common items encountered in the field up to 5/16" in a single pass and up to 3/8 to 1/2" multi-pass. The 40A plasma offers enough cutting power to cut up to 1/2" cleanly and the ability to sever even more. Due to the IGBT inverter design, the machine is compact enough to be placed in most service bodies for transport and can hold up to an 8" roll of wire, which is approximately 10 to 12 lbs of wire capacity.  It's light enough to be picked up and transported by one person without the need for special loading equipment.  The duty cycle of 35% at maximum output means the unit is ready for use and service without encountering long delays or interruptions in operation in every day welding activities.
Type:  Digital/Micro-controlled IGBT Inverter
Output /Process Type:  M A D P
Max Rated MIG Amps:  225A
Max Rated TIG Amps:  225A
Max Rated Stick Amps:  180A
Maximum Rated Plasma Amps:  40A
MIG Amps/Volts @ Rated Duty Cycle:  120V: 125A/ 20.25V @ 35% (Rated at 40° C/104° F)
TIG Output Amps/Volts @ Rated Duty Cycle:  120V: 125A/14.8V @ 60% (Rated at 40° C/104° F)
Stick Amps/Volts @ Rated Duty Cycle:  120V: 100A/24V @ 35% (Rated at 40° C/104° F)
Max Inrush ( I1MAX ) Amps:  120V: 28A
Maximum Rated (I1EFF ) Input Amps:  120V: 17A
OCV:  MIG/TIG/Stick: 64V
Plasma Output Amps/Volts @ Rated Duty Cycle:  120V: 25A/ 90V @ 60% (Rated at 40° C/104° F)
MIG Output Range:  120V: 30-125A/ 15.5-20.25V
TIG Output Range :  120V: DC: 10-125A/ 10.4-15V
Stick Output Range:  120V: 10-100A/20.4-24V
Plasma Output Range:  120V: 20-25A/88-90V
Variable MIG Inductance/Stick Arc Force Control:  Yes
Spool Gun Capable:  Yes
Pulse Frequency:  TIG .5-150Hz
Pulse Time On:  TIG .5-150Hz
Pulse Volts:  TIG .5-150Hz
Standard Drive Roll wire size:  .023”-.030”
Separate wire feeder:  N s
Number of Drive rollers:  2
Max Wire Feed Speed:  120V: 425 IPM
Max Wire Roll Diameter:  8” (up to 12 lb)
Upslope Time:  0-5S
Down Slope Time:  0-5S
Preflow time:  0-5S
Post Flow Time:  0-10S
Foot Pedal:  Standard
Flux Core:  Y O
Air Carbon Arc:  No
2T/4T /Torch latch/Trigger:  Yes
Plasma Cutter Arc Start Type:  Blow Back (Piston type)
PilotArc:  Yes
Torch Type:  TIG: 26 Series Air-Cooled
Recommended Cutting Air Pressure:  65-72 psi
Recommended Compressor Capacity:  30 gallon/5.2 CFH
OK-to-Cut Indicator/Low Air pressure safety:  Yes
Other Features:  H P A M S S S P
5 year
