$0.00
Go to Checkout
SKU# FR-2436-STN
Fab-Rite Professional Portable Welding Station
Welding Table and Tools
$2,499.00
SKU# FR-2436-STN
The Fab-Rite Professional Welding Station is a ideal solution to meeting your work station needs.  This welding work station is designed to fit almost any welding environment where at-station fabrication or production is required. The rolling-caster design and pop-up nature of the surrounding protective arc-shield panels make it easy to store when not in use. The unit includes a two slide-in fabrication surfaces. The first choice is heavy bar grating for general purpose welding and cutting purposes.  The second is a standard fabrication top with 5/8" holes on 2" spacing for light to medium duty fab work. It can also be customized and used with the material top of your own design. Generous sized catch trays built into the base are on either side of the work top to hold consumables and/or prepped parts. The unit also features a sliding "catch" drawer to capture all the drops, sparks and waste material. The drawer can be easily slid out for quick emptying at the end of the work session or shift. Sturdy Pop-up and hinged panels surrounding the unit's base include an installable back sliding curtain to provide a 360 degree flash protection to bystanders. The front and two side panels are equipped with shade 8 rated windows for general work monitoring of welding activities on three sides.  Shade 13 protection is also available at view points along each side for concentrated viewing for instructional activities or QC oversight. This unit is also designed with a vented storage area underneath for gear and fitment of Everlast's optional Nova Cyclo-Air filtration system.
5 year
